E21heads on m10 block?
m3driver49
From what i understand some of the later 02s 75/76 years came with E21 heads. So ona stock later 02 Depends on your pistons and the combustion chamber match, as well as the cam and valve size. If you have a race car I would imagine the pistons are higher compression and the intake valves may be 1mm larger. Your cam would also make a difference in that application.
Allot of info out there, but at the end of the day you will have to determine if there is a combustion chamber match, and if you have appropriate valve clearance in your particular application.
Here is a thread that may shed some light...
http://www.bmw2002faq.com/component/option,com_forum/Itemid,0/page,viewtopic/t,313512/sid,cb55cb896b8f8485d7581736d7c3efe2/
Rey
I'm a BMW Zombie and there's no cure!
