Rancho Cordova Pick & Pull Alert .......................
Just back from scrounging some additional wiring bits and noticed the following new stuff that may be of interest to somebody:
325i with a complete, intact trunk to starter wiring harness in very good condition including the firewall junction block (car is light beige, long side-swipe on the passenger side if I remember right).
318 with the alternator still in it - geared adjuster is chewed up, but everything else looks ok.
BTW, most of the late 70's to mid 80's 5 series used a similar adjuster, so if you want to put a little effort into it, you can grab a 5 series adjusting bolt and bracket along with the 318 parts, grind off the trashed teeth on the 318 bracket, cut the toothed section off the 5 series bracket, braze it to the 318 bracket and use the 5 series toothed bolt - works great.
320 with a complete set of 4 aftermarket 15" alloy wheels - look like 15x6's, flat face 5-spoke star pattern with covered centers. Not the most desirable wheels, but don't appear to be beat up, bent or badly curb-rashed.
