strange clutch issue (video included)
1971Ginger
I'm having a strange clutch issue with my stock master/ slave (ate brand) and 4 speed.
When I press the clutch pedal in slowly (at the same speed as taking a careful step). But if I push on the pedal with a tiny bit of force I feel resistance. I bled the SLA e cylinder last night and nothing changed. I'm at a loss and before I buy a new master and slave cylinder (/mine are only 1.5 years old max)
Please take a look at the video and give me any suggestions on what this might be.
https://www.youtube.com/watch?v=VnhVQzsRffE&feature=youtube_gdata_player
Thanks!
1971- 02-Malaga -(Ginger)- 2nd owner
1973-02- chamonix (sold)
pardon any grammatical errors in my posts, im probably on my cell phone.
I have had this exact same issue twice. If you rest your foot on the clutch pedal very softly press it will go to the floor with no resistance. If you press quickly with force it will work. Both times I had to install nw clutch masters because they were bleeding by(confirmed both times by a real mechanic, not just me). One thing to make sure of when you install the new one is that the clutch pedal is the same height as the brake pedal. I
had my clutch pedal about an inch lower (not sure why)when I had this issue both times. On the new clutch master I adjusted it out so that the clutch pedal and brake pedal are even. Has worked great so far. So order a new one from BLUNT and adjust it...should fix it
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
