Pressure-Testing Heater Core
I was about to reassemble the heater box when I realized I hadn't pressure-tested the core. I read online about cutting an inner tube, hose-clamping it onto the pipes, inflating it to 5psi (yup, low pressure -- this ain't an evaporator core), dunking it underwater, and looking for bubbles. Voila!
Plus, as a bonus, you get the "WHAT IS THAT IN THE SINK?" effect on your wife!
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
My wife? No, tight as a drum.
BOOM!
Sorry.
(It did not leak. The heater core.)
Ha! That's so much quicker than the fittings I jury- rigged to do that job.
Neat!
Plus, there's a lot lower danger of accidentally pressurizing it to the 90 psi of the compressor....
...but I'd go to 15 psi, myself- I found that some cores can crack at the end
tanks, and the cracks only really leak when you're running the same
pressure as your radiator cap.
Toby, so 15psi is good? Things I read online at other sites said 5. I didn't think to tie it to the cap pressure, but that makes sense. Thanks!
Bet you could do the same thing to test a radiator with a length of plastic plumbing pipe, two pieces of inner tube and four hose clamps. Install the cap and pump until the cap pressure released.
Just be careful.
Remember - with 5 psi, the inner tube won't grow that much. With 15 psi, it will grow more. If you want to test higher than 5, I'd build something with hose that won't expand and some fittings.
I agree with the "clean then test" theory. Crud will hold a lot of pressure.
FAQ Member # 2616
-- My wife.
Hack, thats what I call thinkin like a German, the longer we are at this the simpler it becomes
Happy Trails to u~ Dave Miller
76 Golf~Rhiannon~BM Mascot~*~97 328is~Silver Ghost~*~68 1600~Wisperin Beast~*~70-02~Bumble Beast~*~76 02~Beast~
Keep smilin all the way
So how do you pump up the tube to 15 psi when a tube without constraint (ie, outside of a tire) will blow up at 15 psi?
Constrain it.
Packing tape.
Packing tape
Yipes! Not duct tape???
I'm with Jim, that thing scares me!!!
And yeah, Rob, I found a core that had cracks in the end tank (maybe it froze?)
It held both water and air at 5 psi, but at the 13ish of the cap, the cracks would
ooze coolant.
So now I test at 15, and if it explodes, then it was never meant to be.
heh
