Is a 0.9 ohm BALLAST resistor the same as the resistor wire?
I have a 1976 that has the resistor wire in the wiring harness. Measures about 9 volts at the coil with all leads connected. I also have a new bosch w0133 (made in Brazil it says) coil which says to use a 0.9 ohm ballast...is the resistor wire in the harness the same thing as what the coil calls for, or is a ballast resistor an external resistor (who knows, ceramic, amp rating, whatever) ? Thanks!
Yes, the ballast resistor takes the place of the resistance-wire. In other words, the wire is just a long resistor with the same resistance as the ceramic ballast.
Like Chris_B says, make sure there is a relay that bypasses the ballast while the starter is cranking. I personally don't like the wire because it can overheat and set the car on fire, without blowing a fuse, if it shorts out.
Too many cars.
Thanks guys. If I read my schematic correctly, the starter solenoid shoots a full 12v to the coil when cranking over and once started, drops it down to about the 9 volts I measured. I was just puzzled about the terminology. Ballast reminds me of old flourescent lights or something else. But hey, 0.9 ohms is 0.9 ohms.
