help, or support fuse 11 blows on my 72 tii
dwalex
I am not familiar with the details of the Kugelfischer FI system. In most modern electronic systems the pressure is controlled by a mechanical regulator that bypasses excess fuel back to the tank, once a predetermined pressure is reached. If the regulator malfunctions, or the bypass line is pinched or plugged, the pressure can get extremely high (over 100 PSI) and the load on the pump would cause it to draw excessive current.
Is there a similar pressure regulating system in the your Kugelfischer, and if so, is it working?
Have you measured the pressure out of the electric pump?
Too many cars.
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
well, finally got her put all together. The initial prognosis of a bad fuel pump was wrong. However, I did replace it with a 5 series pump for longevity purposes. In addition, I found a detached wire (hot) for the cold start valve (also on fuse 11). This was the culprit.
Thanks everyone for all the help
Dave
72 tii, tupelo honey
67 gt-6 ###%&$*;###!!
03 z-4 name undecided
12 fiat 500s quiche lorraine
