Clutch Problem
duckdudess
My clutch engages slightly at a stop sign/light with the pedal fully depressed. It happens frequently but not consistently. I replaced the clutch master cylinder with no effect. No fluid appears to be leaking from the slave either. A weird thing I noticed yesterday is that when it begins to engage, while stopped (clutch pedal in, right foot on brake), when I rev the engine slightly, it disengages. Any ideas?
Details:
New clutch, pressure plate, throw out bearing, composite slave cylinder 3000 miles ago done at time of engine and 5 spd upgrade. All brake/clutch hydraulic lines rehabbed or replaced as needed. Fluids flushed and replaced with Castrol LMA, all lines bled.
I did try a pressure bleeder. I started with the brakes, which seemed to work fine, but when I opened the bleeder on the slave, not much fluid came out. I reverted to the two person operation (3 clutch pumps, hold pedal to floor, bleed, close, repeat). Perhaps I did not have enough pressure in the Motive Bleeder? Never having used one before I pumped it up to 15 PSI. Should it be higher ?
normally what you describe is caused by failed slave
or master cylinder seals - but you note a mix mash
of - old - used - rebuilt - new - parts so who knows which
of those are the cause - everything is questionable ???
if it's not bleeding/air in system then pick a part to replace
'64 R27 250cc #383851 18,000m
Thanks CD. The net is that other than the brake hard lines everything is new (3000 miles on the slave, <100 on the clutch master). I started by replacing the master which had no effect, adjusted the "pedal rod" until the clutch pedal was in line with the brake pedal, still no change and I can/will change the slave since I am running out of things to try.
Hi,
as i read it you replaced all the parts
for the clutch and its operation except
for one part that most people overlook.
the pilot bearing needs to be replaced
at the same time. this little bearing
holds the weight of the input shaft and
keeps the internal gears running true.
when the bearing begins to fail it
usually binds on itself. the result of this
binding is that the input shaft rotates with
the crankshaft. if this problem remains
after you bleed the clutch master and
slave cylinder then you most likely
will have to replace the pilot bearing.
let us know the outcome.
good luck
stone
stone racing co
phila pa 19123
The 5 speed requires a specific pilot bearing dimension which is different than the stock 4 speed. So it may have been new, but was it the right one? If not, even full extension of slave will not totally release the pressure plate. Coming back to the lack of fluid at bleeder, is there a rubber hose in that line, and if so, is it new-ish?
elaborate: Do you mean the Throw out bearing here. Where if the user has a 228mm flywheel/pressure plate/clutch and the 320i TB instead of the 323i TB the TB will not fully depress the pressure plate.
I read Stone to imply a partial or complete seizure of the pilot bearing within the crank cavity causing the crank to force the movement of the trans input shaft inadvertently.
Apologies for confusion. Trying to multi-task here. I meant throw out bearing.
Here's what I got from Mike Miller some years ago.
"The 323i release bearing is 30mm and the regular 2002/320i release bearing is 25mm. (The former is old style steel and the input shaft flange it rides on has to be lubricated; the latter is the new style dumbed-down plastic kind that we're not supposed to lubricate, but I do anyway.) You have to use the 30mm 323i release bearing if you want to install a Getrag 245 gearbox in a 2002 with a 228mm clutch. It is part number 21 51 1 204 525.
Best regards,
Mike Miller
BMW CCA Roundel Magazine Technical Editor
techtalk@roundel.org
auspuf2002@aol.com
I had the same problem with the C/R 5 speed in my car - I don't recall specifies of sizes, but I installed transmission after changing to 228 clutch with the wrong bearing and spent days screwing around with hydraulics and push rods until the bearing issue dawned on me. Took out transmission, changed bearing, and all was well.
But I'm still curious about the lack of fluid.
The engine is a stroker, with an S14 crank. The builderknew it was being connected to a 5 speed so I am assuming that it is fine, especially since the car ran without fault for the last 3K miles.
On the line between the master and slave, it is a combination of rubber and hard line. Both 3K miles old.
Sorry, for replying out of sequence, but I appreciate the help. This car has a stroker M10 motor, a 325 flywheel with a "big" clutch and pressure plate and the new style (plastic?) throw out bearing. Again, all of this worked from day one (3K miles ago) when the new engine/clutch/pressure plate/hydraulic system was mated to the used 320i 5 spd, until a couple of weeks ago when I started having this weird problem.
Has this been a problem for 3000 miles or something new? If rubber hose is new, we can rule out swollen hose problem. I have read that bleeding those later style slave cylinders is difficult because of upside-down nipple location. Bav auto sells a special tool to bleed it while unbolted from bell housing. I have one somewhere but haven't used yet (awaiting O/D 5 speed conversion).
