Chrome / Stainless Sill Trim Fitting
mavhh
Hi, i'm just in the finishing stages of completing a restoration. I have obtained the white plastic clips the push into the sills, and the chrome / stainless strip that runs full length of the car below the door line. However... I cant seem to clip them on reliably! Some clips pop off when others engage, i certainly wouldnt want to drive like it! Am i missing something? Should there be some nuts/bolts? Any tips much appreciated!
If its important, the car is a 74 right hand drive british 2002 Automatic.
Dave
The ones that have been available for the last couple of years do not hold all that well. Mine are just barely staying on. The trim does not come off in driving, but it doesn't take much to just pull them off.
What esty posted is a link that you can clic on for much info on this.
Bob Napier
trim (side trim, I think) on an E21 and have morphed into 2002 rocker trim clips courtesy of BMW AG. The original small black plastic clips did a much better job of holding the trim in place but have been NLA for years.
You might try VERY GENTLY squeezing the trim piece's lips together with padded arc joint pliers to make the trim fit more snugly on those clips that are loose.
cheers
You know what - I was thinking that. Put some plastic plug type inserts in the holes (like a modern cars registration plate has) and use some nice quality dome head stainless screws...
I've got no confidence in the plastic clips at all!!!
The tip of slightly tweaking the metal itself for a snug fit worked for me. I was aware of the issue beforehand, so I was ready to play with it. Mine are on nice and snug. Now, with that said, I assume you know that the forward mount is a plate/bolt style fastener like the belt line trim? That really gives it a good solid hold, too. Good luck!!
Stephen
