E30 Steelies..... 185 or 195
BobBreed
On 13's I used 185/70/13's as this is close to the original diameter. If one were to use that as a baseline, the 195/60/14 would be the correct +1 setup. 185's would be like a 175/70/13 in diameter.
Hope that was usefull.
John
1665778
195/60 x 14 fits just fine; I have IE Stage One springs and Bilstein HD's:
I always do it right the second time.
1970 2002 Chamonix (Fiona)
1976 2002 Chamonix (Blanche), '73 2002 Colorado (Nemo), '72 2002 Riviera, '74 2002 Atlantik, '71 1600 Sahara (Binkley) all sold
185/60 R14 gives you the correct tire dimension so your speedometer is accurate.
Actually, 195/60 is closer. Stock 165r13 is about 23.13" tall. 185/60-14 is about 1/2" too short, at 22.74". 195/60 is 23.21", and 185/65 is 23.47". 175/70-14 would be 23.65".
All that said, a lot of '02 speedos are off anyway. With 185/65-14, mine should read a tiny bit low (it's taller than stock), but it actually reads about 10% fast.
-Dave
Colorado '71 2002
'17 VW GTI Sport
