Disaster - What to do
hegedus
I spent last year restoring a '72 tii to be a great daily driver.
Found a no rust car with a rebuilt engine in a stalled restoration. Finished it up with new paint and interior and other goodies such as LED taillights, upgraded starter and alternator, wifi enabled air/fuel sensor.
Fun car to drive. Then engine failure including a hole in the block and maybe some head damage.
What to do? Fix or sell off?
Hi,
a good long block takes only one weekend
to install and you are back on the road.
post on the wanted and wait to see who has
a used motor. there are more engines than
bodies left. you can request help from
your locals and get some fine
help and also alot of knowledge. just to
make sure it is done right you should limit
beer intake to two per hour per worker.
a cook out might even be cool. i would
jump in but the plane ticket is too much.
good luck
stone
stone racing co
phila pa 19123
Guest gliding_serpent
I feel your pain. Is this a numbers matching car/engine? If it is, rebuild. If not, save it for parts and get a new engine. Remember that you know what goes into a rebuilt engine you oversaw... but not one that someone else did. Do your homework.
Fix it!
That way you can 'close the circle' since the engine seems to be the only thing done by the previous owner. See it as an opportunity...
rtheriaque wrote:
Your car really looks great. I say fix it! I'd be glad to loan you my engine hoist and engine stand. I'm here in the bay area and would be glad to lend a hand when I can.
Thank you very much for the offer. I will keep you in the loop on what I wind up doing.
It's very discouraging when it happens (something similar--but not as serious--happened to me that required 500 miles on a tow dolly behind a U-Haul truck) but just jump in and fix it. Lotsa parts available from friends on the FAQ and even more advice...many 02ers in the Bay area who are more than happy to help out a fellow 02er.
Keep us posted--you have a great looking car!
Definitively repair it that car looks awesome. I wish mine looked like that, I'd trade you my whole running car for yours!
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Record (for me) for motor swap was 6 hours. By myself.
Fixit!
And I'll agree- used long block to start,
then see what you think after that...
Should take a weekend or 2.
FIX IT! you have worked through the expensive stuff already good body= everything in my opinion. Now might be the time to build up a bit of a performance engine or do an EFI engine or S14, or m20 or m44 or whatever you fancy.
You've already got a lot of stuff sorted on your car, fix the motor and keep it running!
-Nathan
