Am I over my head trying to rebulid my 32/36 myself?
Am I over my head trying to rebulid my 32/36 myself? I have the rebuild kit from Pierce Manifold and the Hanes Weber book, but have never done anything like this before. (Dad never showed me much with what is up with the car)
Any way is a full rebuild too much for a carb newbie?
Thanks!
Ben
Ben in Denver
2000 Touring INKA 3357390
I'm in the same boat, someone on the board shot me this website, very detailed, take a look.
www.mkiiisupra.net/bbs/showthread.php?33876-GUIDE-Rebuilding-a-Weber-32-36-DGAV-Carb
Bill
1973 2002 Chamonix sunroof (soon to be M42 swap)
2015 Ford Explorer-Wife
1999 Jeep Cherokee
1991 318i convertible (donor)
Probably not. But it will be time consuming, getting up to speed/. The Haynes book and Pat Braden's Weber Carburetors are good
companions. You need several widths of good- quality flat- bladed screwdrivers of very good quality, some organizational ability,
patience, and a digital camera in case you get stuck. But if you're careful with stuck screws and jets, and put things back the way they were
originally, you can't do it any harm at all. And usually, you'll fix it.
My take is that a carb's not a bad place to start learning to work on a car- it's smaller, you can do it inside, you aren't in danger of hurting yourself,
and they DO listen to reason, if you know how to hear them. And let's face it, a 32/36 is cheap enough new that, if you were to send it out to
be rebuilt, you'd end up spending a good fraction of a new one.
So if you destroy it, you're not out much, and you've learned a TON.
Go for it.
Post up if you get stuck.
fwiw
Will be up in denver mid day monday and have time before my work shift which starts at 6pm if you want a hand.
Daron 3 oh 3 324 2355
Or i can send you a scan tonight
The thing that made it easier for me is I replaced one part at a time with the carb still installed.
Replace a part drive the car, if it turned out ok. Replace another part. Do the same.
This kind of helped me learn if what I was replacing helped or hurt...
ira
Thanks Daron, but I am working as well. We definatly need to go fo a drive tho. Soon! 3 oh 3 351-9032
Ben
Ben in Denver
