adjusted the valves today .....
finally worked up the energy to adjust the valves. Even had energy left over to clean the spark plugs, since removing the spark plugs is Step 1 for valve adjusting (in Carl's book, that is).
Anyway, we had an early thread on the topic:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,380220
SO, what I wrote in that topic was that you can adjust 2 valves with one setting of the camshaft.
Here's a chart I made up to show what 2 valves can be adjusted .....
Cheers,
Carl
actually I have found that you can do three valves at once: the 2 that are closed on a particular cylinder and one other that will also be closed at the same time. That being said, I end up not just going thru them once, but checking and re-checking as I rotate the engine thru complete cycles, so it doesn't end up saving any time to do three at once.
