Megasquirt wiring question
austinmf
Cable shielding is grounded ony at one end of the cable
unless you're a vidiot...
heh
What does this mean? Many who don't know about shielding cables want to connect the shield at both ends to semething. In this case the shield is not grounded at the sensor but is connected thru any connectors back to an area that has a ground available. It could be grounded at either end. Just trying to help the guy out, which he does need because of the follow-up question what the "loop" was for. And it is the schematic representation that all the leads within the loop are to be within the shield.
Thanks for all the input! I would have tried to ground it probably on both ends. I am new to wiring but am slowly learning!
I am a couple years behind you guys.
Not sure if I can make mid America or make the drive to vintage. One more year down.
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
What exactly is PIN 7? It is the loop around the shielded wire. What connects to it? I am new to this obviously... could not find it in the search
To make things real simple: take the shields from both cables coming to and going from the controller and attach them to the #7 wire coming out of the plug. Attach a jumper from that #7 wire to #10 wire. Run that black wire from #10 wire on the plug to the manifold ground connection I told you about in my earlier post You do not need to do any other connections from the shield wires to ground.
Mike Katsoris CCA#13294
74 InkaGangster 4281862
76 Estorilblau 2740318
Found that actual cable on eBay. They sell it in 10 foot sections.
You can buy the cable at Radio Shack. You might also try Home Depot. No kidding.
Too many cars.
