What do the guards look like under the 2002 turbo flares?
gretchen72
What do the guards look like under the 2002 turbo flares? I assume they're chopped, but I've never seen a turbo with the flares off...
Also, what does the front clip look like under the turbo spoiler? Is there a slot cut so that the main hole feeds the radiator?
Cheers
Ad
the slot in the front air dam is for the engine oil cooler
it does not feed air to the coolent radiator
black bracket is for the TOW HOOK
chassis # 4291334
'64 R27 250cc #383851 18,000m
Thanks guys!
The Guards are as I expected, but the air dam holes go nowhere... odd? I know the round hole is for the compressor intake, but I'm surprised about the rectangular one. Mine is a twin round hole, so, maybe I'll make them brake cooling ducts, or perhaps fog light positions?
I'm assuming the little tiny hole is for a towing eye?
The center hole is for the oil cooler, the single round hole on the right side does not feed air the the Turbo air inlet. It ducts air through a 90 deg bend tube tha blows air ON the turbo for cooling. The air intake is a hole in the core support just ahead of te air filter housing on the upper right side of the engine bay.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
