Rear Tranny Mount thickness ?
02G
Can someone please provide me with the dimensions of the rubber bush
that supports the back of the tranny ?
What height should the tranny sit above the crossmember ?
Ref the attached image.
The PO used a locally available bush, but I suspect that the height is incorrect.
thanks in advance
G
PS. I know the bolts on the guibo need to be swopped.
April '71 2002 LHD - hard won daily driver
another way of gauging if the mount is 'correct'
if the drive shaft alignment is straight so
when it's hand rotated the Guibo does not
flex and wobble which causes a failure.
So fit a mount that maintains a tru running front
shaft Guibo- it maybe called a "flex coupling"
but they dont last long flexing and wobbling
there are a few mount options
standard 2002,
or others from larger model bmws - others here might offer
model and part numbers. Wait................
'64 R27 250cc #383851 18,000m
