VDO Oil Press Gauge New
Bought both sender and gauge, old sender was bad, don't need the guage. 0-150psig, VDO Model 350-041. $25 shipped in US.
Buy your sender separately from somebody like: http://www.egauges.com/vdo_send.asp?Sender=150PSI_10Bar
Jimk. I'm interested. What series VDO gauge is this, do you know? Where do you mount the sender? Thanks.
It is a cockpit series. Best to do a google on the part number that I listed.
The sender is mounted where the existing switch is located on the rear of the head. If you can find it, there are sensors with straight metric threads to match, but most folks install an adater that fits the straight threads in the engine and a 1/8" npt sender threads into that. Get a sender with a switch and a terminal for the gauge. See the link. I believe the stock switch is 7psi (it's usually stenciled on the stock switch but in bars) There has been a recent thread in the General area on the sender/adapter.
