felix_666
Motor mount / suspension torque vales
4 posts / 707 viewsLast Reply
I have searched extensively, checked the faq/blue book and haynes, but nothing. Maybe I'm not looking hard enough but I just can't find them, or maybe strange lingo?
Seems to be about 9 nuts all up, left and right.
Need torque values for:
two for right mount to subframe. M8
right mount to bracket M8
three for right bracket to engine M10
left mount to subframe M10
left mount to bracket M10
Thanks.
M6 10Nm
M8 25Nm
M10 50Nm
These are good for any normal thread 8.8 grade bolts. You don't have to worry where they are installed unless there is something very special. If it's fine thread or harder grade then it's different.
Tommy
C.D. you should have a look in that link you posted. As I said, I looked extensively, it only has one value for all the torques I require, which vary in size.
@ Tommy
Thanks, I have used a cap headed bolt which is 12.9 for one of the right mount to sub bolts, do I need to torque it higher?
