Guest gliding_serpent
73 2002tii flywheel machining specs?
5 posts / 754 viewsLast Reply
Does anyone know the specs for refacing a tii flywheel? My searches have come up short.
Thanks, using the correct lingo makes all the difference, although pickings are slim.
"When getting the flywheel resurfaced, make sure they know to leave a .020" lip for the clutch disc to ride on. As quoted from another member "The clutch disc rides on a raised platform. The mounting for the pressure plate sits .5mm "below" the central wear surface."
Not Tii specific but I suspect we are in the ballpark.
yeah, half a mil is what they came with.
I had one done at a full 1 mm once, and it worked, too.
