MaxSil piano top piston compression ratio question
austinmf
Based on the photo they look to be 9.5:1 Look identical to the ones I installed in my motor...In fact I thought I had installed JE but I may have installed the Maxcil pistons in my motor
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
I would call MaxSil to confirm. See if you can get a part number, etc. BavAuto sells those as a 9:1 piston, I think.
And Nick, there is a difference between the JE and MaxSil. I believe JE is forged and MaxSil is cast. The difference is subtle, but there is a difference.
-David
1972 2002 - 2577652 Follow the fun
Yep I built 2 engines. Used JE in one and Maxsil in the other. I believe the engine I have in my car now has the Maxsil. At any rate the Maxsil pistons I used I purchased on eBay from the same guy. I know mine were 9.5 but I sent a message prior to purchase to confirm
Ah, gotcha.
-David
