Sign in to follow this
nbristow01
PN for the 5 speed TO bearing
8 posts / 404 viewsLast Reply
I run a 215MM clutch with my 5 speed so I should be using the 323 TO bearing from what I read. I may have to install a new setup this weekend and will need to get the TO bearing from BMW local to get it on time.
Anyone know the PN for this TO Bearing?
but bmw wont have that on the shelf I can send you one today if you need it
Not sure if I will need one until that MC I ordered from you comes in. It may be here today. I will let you know. Just trying to avoid overnight shipping charges so thought I could get it local
delivering today
9405510200793489322225
Priority Mail®
Processed at USPS Origin Sort Facility
December 10, 2012, 10:53 pm
SAINT PAUL, MN 55121
Expected Delivery By:
December 12, 2012
I thought you needed the 323 TO bearing only if running the 228mm flywheel. I thought the 215mm uses the standard TO bearing (maybe the E21?). I have a 228mm so I know you need the expensive 323 part.
I could be mistaken though...
And thus my question because that is what I thought. Everywhere I read on FAQ it seemed the 228mm clutch used the 323 TO bearing. I am hoping someone chime sin with the correct PN for the TO bearing used with the 215mm clutch and 5 speed.
this is correct. the 320i's used the 215mm clutch
