Sign in to follow this
Inka’d02
Complete engine & trans in CT:SOLD
1 post / 540 viewsLast Reply
I pulled this out of a 75' 02. The motor and transmission have 121K on them. Complete with a Weber 32/36 downdraft.. Even compression in all cylinders registering 115 psi cranking/cold; would probably be in the 120's once up to temperature.The transmission went into all of its gears without a problem. I did not see any smoke after having it running for 10 minutes or so. The motor will need a water pump since its bearings feel a little crunchy but it does function; keeping the motor cool for the 10 minutes I had it running.
I gave it a quick degreasing and power wash after removing. I also removed the AC compressor and air pump.
This would be a great candidate for a daily driver or someone who needs a temporary set up while they rebuild a motor.
Reduced to $500 OBO, I want this out of my garage!
Video of it running available upon request, please contact me at Geraci2002ATgmailDOTcom
Located in CT; pick up only.
Thank,
Andrew
