JLENHAM
Bad Coil Confirmation?
2 posts / 389 viewsLast Reply
If I read the posts correctly that turned up on a search for coil tests, I think mine is bad.
Blue Coil
DMM reading across + (green wire terminal 15) and - (black wire terminal) is 3.4.
Resistance across + and center (center post to distributor cap) reads infinite and should be 8-9?
All reading taken with wires removed from coil, no ignition on etc.
Does this confirm the coil is bad?
Thanks!
Yeh, probably.
Check center cap to case, just to be sure, though.
It could be a proper transformer, not a coil.
