Can this be fixed?
Dirka
Ahhhh nooo.
If the piece that fell is mostly intact maybe you can use some epoxy glue and then refinish the whole thing?
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
I cut mine symetrical, hence the name toothless on my blog. I tried using fiberglass repair a few times but the piece never had the original strength. I thought of possibly putting some hardware cloth behind the opening and fiberglass repair it into the dam but I lost the piece. Wound up picking up.a.zender dam from the boneyard for $10 when the turbo dam gets too trashed out. I'll update witth pic of dam tommorow.
Daron
If you have the missing part you can use expanded steel - mesh behind the part that broke off.. Then use fiberglass to add a support layer with the mesh.
Also you will need to rough the surface up and grind the point where the broken areas join then fill in that small V area with fiberglass.
69 Baur 1600
71 Euro 02
75 02 w/ box flares
72 E3 73 E9
85 Baur 323 E30
99 Z3 coupe track car
08 Z4 coupe DD
