adamgraves
5 speed trans has no speedo cable connect??
8 posts / 818 viewsLast Reply
so i've been saving up parts and now about to install 5 speed and LSD and figured out the 318 i got parts from didn't have the speedo cable connection. any idead on a fix for this??
where the speedo cable connected on the E21s--or so I've been told. Check your 5 speed to see if there's a plug in the proper location; if so you can add the drive gear, washers, collar etc and you'll have the proper drive cable setup. Check the archives on this--it's been covered sometime since the FAQ board started.
If there's no plug, electronic speedos and GPS speedos would be the way to go.
cheers and good luck
Yeah, the E30 didn't have the spigot.
You'll need a different rear mount, too.
You CAN use the E30 speedo and pickup- there's a thread on this somewhere-
someone strapped the 'tone ring' onto the halfshaft, and it worked-
but getting a 2002 mechanical speedo to work with it is going to be hard.
And/or expensive. Probably more than an E21 trans is going to be.
Sorry.
well, that sucks. got the wrong tranny. i'm puting it in anyways. who really looks at their speedometer... keep my eyes open for a 3-part tranny down the road for cheap. point was to get 5 and LSD so i guess i'll forgo knowing how fast i can go.
next is the FI install, hope i got those parts collected right...
I think the electric VDO speedos can use a magnet mounted on the driveshaft like a bicycle speedo.
John
