73 2002Tii engine rebuild parts list. Help appreceated
Guest gliding_serpent
Hello all. I am having my 1973 Tii's engine rebuilt locally. It is running dual webbers but I have the original KF injection and finances pending may get it rebuild and put back on.
The engine is currently apart and the only real issue was major scoring in cylinder #1. 90mm pistons will do the job (just... we were hoping to get by with double oversize) and I have sourced them from IE. As this is the first rebuild I am looking to get it done right and freshen things up. I have been in touch with a few people trying to get an idea of a parts list. As I am not a mechanic I am limited knowing what to replace "while I am in there" as the service will cost the same if I put in new or old parts. I would love if anyone had old parts lists that they generated for their own rebuilds.
Thoughts would be much appreciated.
A good link:
http://www.penskeparts.com/DiagramsMain.aspx?vid=47141&rnd=03192010
IE lists:
BMW 4-cyl Engine Rebuild Parts List
Head
Cam Sprocket (Single Row) $44.00
Cam Sprocket (2-Row) $98.00
Cam Sprocket - Adjustable (Single Row) $125.00
Cam Sprocket – Adjustable (2-Row) $179.00
Rocker Shafts $72.00 /set
Rocker Arms (Original) $26.00 ea / $152.00 set
(FEBI)
HD Cast Rocker Arms $25.00 ea / $200.00 set
Rocker Arms - 7075 BILLET $85.00ea / $680.00 set
Rocker Adjuster Eccentrics $4.90 ea / $39.20
Rocker Oversized Adjuster Eccentrics $7.50 ea / $60.00 set
Lash Caps $2.00 ea / $16.00 set
Valve Springs (Standard) $8.95 ea / $71.60 set
Valve Springs TiSA (Requires recessing spring seat) $ Call
Valve Springs (ISKY Dual) $11.25 ea / $90.00 set
Valve Springs (SCHRICK) $ Call
Valve Springs (Ireland) Dual $115.00 set
Intake Valve (46mm Standard) $16.00 ea / $64.00 set
Intake Valve (46mm Stainless) $21.00 ea / $64.00 set
Intake Valve (Oversize 1mm) $Call
Exhaust Valve (38mm Standard) $37.00 ea / $148.00 set
Exhaust Valve (38mm Stainless) $22.00 ea / $88.00 set
Exhaust Valve (Oversize 1mm) $Call
Upper Gasket Set $73.00
Tii/Turbo Head gasket
w/ Cutting Ring $Call
Small Hardware Set: (Keepers, thrust washers, rocker
retainers, circlips, adjuster bolts
nuts & washers, rocker springs,
studs, nuts, etc) $184.00
Block
Main Bearings (K.S.) $70.25
Rod Bearings (K.S.) $35.00
Rod Bolts & Nuts $51.00 set
Oil Pump (original) $Call
Oil Pump (aftermarket) $ NA
Oil Pump Drive Kit (Sprocket & Chain) $34.75
Timing Chain (specify 1 or 2 row) $56.00
Timing Guide Rail $7.00
Timing Tension Rail $38.00
Tensioner Piston & Spring $18.50
Water Pump-2002 (original) $Call
(aftermarket) $47.00
-Tii (original) $Call
(aftermarket) $52.00
-320i/318i (original) $Call
Crank Sprocket (2-Row) $70.00
Freeze Plugs (Specify year of block) $18.50 set
Lower Gasket Set $51.00
Oil Pan Baffle (Weld-In) $35.00
Oil Windage Tray (Bolt-In / Sandwich -
Requires extra Pan Gasket) $45.00
You don't need to have your worst cylinder dictate your piston size -- the closer you get to standard, the more options you have -- so think about sleeving cylinder #1.
