joe18d
Would an early grill fit on late 1976 2002?
18 posts / 2943 viewsLast Reply
I have a 1976 '02 & really like the look of the early grills. Are they a straight swap or even close to the late grills?
Thanks, Joe in NH
They're not a straight swap! On square taillight cars, the plastic side grilles run right up to the center grill. On round taillight cars, there's a strip of body-colored sheetmetal between the side grills and the center grill.
Joe,
A number of ways to get a little creative; on a '76 2002 I had, I painted them to give them the pre '74-'76 look; took some masking, etc..they came out pretty good. Of course the key would be to maybe pick up a set of used
side grilles for your car, this way, with the current ones off, you can leave them off for a day or so, while you're prepping/painting. I picked up a set of
side grilles from a salvage yard for $20, there were 2 '74-'76 2002's
in the salvage yard I went to, one of them the grilles were gone, the other 2002, the 3 piece grille was in the trunk., just about perfect condition.
Tim
Stu,
It might have the earlier nose panel
Tim
Yeah, I thought that might be the case. Thanks.
No.
It's quite difficult.
Impossible if you don't own a welder.
Why will this question not die?
No.
will a sync link work on my weber 38/38 with a 5 speed....and i need some new 13 inch tires where can i find them
" will a sync link work on my weber 38/38 with a 5 speed...."
only if it is for a 3 bolt flange. I hear a member of the forum has some money of mine for two years to make an adapter and can't contact him.
Yes, but it has to be the fine- spline 3- bolt flange.
The coarse spline is a different length....
heh
Simple question. No need to be an ass. If you have something constructive then add a comment, if not, be quiet.
Joe in NH
PLAY NICE GUYS AND GALS!
IT'S THE HOLIDAYS DAMMIT!!
Like
p.s. i think the HUGE Alpina wheels look silly/stupid on this car
good luck next time.
Why Toby, why do I need "luck next time"??? Are you somehow sharper or more intelligent than the rest of us? Please do explain yourself. My question was / is a simple one. If it is below you then just shut up & move on to the next post. If you have something helpful to add then please do.
Joe in NH
Guess I'll just shut up and move on, then...
