Sign in to follow this
VintageAutobahn
Price drop: 220 KH speedo, Schrick 316 camshaft
7 posts / 2794 viewsLast Reply
These carburetors appear to be in good condition but I would assume they will need a rebuild. The linkage is in good conditions and does not appear to be overly worn. These are original solex carburetors from a 2002 ti, manufactured in "West Germany". SOLD
Untitled
This camshaft is used, but as the pictures show the lobes have almost no wear. This is a race only camshaft. IE currently sells these for $690 they say " The genuine Dr. Schrick 316 degree camshaft is for racing only. It will give the M10 usable power above 7,500 rpm. Because it has such large lift, the first two cam journals on the head must be enlarged 2 mm. The 316 is internally oiled, and an oil restrictor should be placed in the block. Note: You must use double valve springs with this cam." $325 shipped
Untitled
Untitled
Untitled
Untitled
This speedo is from a European tii. These 220 KM unit were used in Tii's and AlpinA cars, as opposed to the 180 and 200 KM speedos put into standard 02's and Ti's. Tested to be fully funtional. This will fit in any year 2002 cluster, but matches 72-73 gauges if I remember correctly. The W0.91 stamp indicates that this is geared for a car with a 3.91 rear differential $110 shipped
Untitled
Untitled
Untitled
All prices are OBO, please ad 3% for paypal. Shipped prices are to 48 states.
