Guest Anonymous Posted July 14, 2003 Share Posted July 14, 2003 Right now I have a breather hose straight from the valve cover to the air filter base. It burns about a quart of oil every 500 miles. Can anyone recommend a breather box to use for this setup? Thanks, Will 75 Fjord Smyrna, GA Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 14, 2003 Share Posted July 14, 2003 if your problem is oil consumption: find/fix leaking gaskets do leakdown test could also be: valve seals, rings actually the valvecover to aircleaner base will help seal your rings, by venting the case and is the best set up. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 14, 2003 Share Posted July 14, 2003 before I get to this reliable old beast. Can't I put an oil separator in the line between the valve cover and carb? From the looks of the air filter it is sucking an awful lot in. . . I know when I get to this engine I will have to go all out, hi-comp pistons, head work etc. and I need to advance in my career quite a bit before that bill hits. . . right now I am holding off the urge to go with the dual dellorto setup. . . by the way that Alfa1750 guy offered to sell those things with venturis of my choosing if I tell him before the ebay purchase. Hmm. . . Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 14, 2003 Share Posted July 14, 2003 www.summitracing.com or www.jegs.com they both have "catch tanks" for under $20 w/petcocks on the bottom that you should be able to use and then just re-insert the oil back in the motor... : ) yeah that alfa guy promised my carbs were all "excellent and ready to run"... nope, not close. all needed rebuilds and one even had stuck jets etc due to the bad corrosion. You get around to doing a set holler at me. ps what type vw motors you building. I have most of an 1835 aircooled for cheap. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 15, 2003 Share Posted July 15, 2003 Some folks just run a a long hose down into the tranny tunnel and let nature take it's course. Whether or not you decide to run a catch tank your motor will run better without the breather going to the intake. Jonathan T. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 15, 2003 Share Posted July 15, 2003 my friend has the set up from a local racer supply store that is very similar to Summit's . I bought a little K&N breather for the top of a home-made rig that is not yet finished. Probably cheaper to buy the whole rig from Summit, screw it to a side and you're done and clean in the eng. bay.I dont know about using that oil again in the engine- i suppose it is o.k., but,....You can see in the picture, I am running the same way you are right now Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 4, 2003 Share Posted November 4, 2003 Britt, you seem to be good at talking behind the back.you were offered a complete refund but you refused it.try resolving things directly and not behind the back-its not a good way to go. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 4, 2003 Share Posted November 4, 2003 Like a "behind the back pass"? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 4, 2003 Share Posted November 4, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 5, 2003 Share Posted November 5, 2003 (nt) Quote Link to comment Share on other sites More sharing options...
