Anyone fit a sync link to their 32/36 automatic?
autobon7
Have been reading about the sync link for awhile and most agree that if set up properly is a good bang for the buck. Most comments mention better pull down low after the install. I have a 75 automatic....seems like a good fit? If anyone has any 1st hand experience, positive or negative, please pass along. Also....if you had to change your jetting or modify the CD prescription.
1995 Toyota Landcruiser
1975 2002A
1989 Dodge Raider (sold)
1974 Toyota Landcruiser (very sadly sold)
1994 BMW 530i (sold)
1992 BMW 325i (sold)
1970 2002 auto sunroof (sold)
I have a 4 spd..my 32/36 was running great before I added sync-link when I added sync link Wow.....is the phrase that comes to mind....
I truly believe you will love it...I say do it...
ira
As a long time owner of a couple of automatics (my '75 for 31 yrs. and my wife's '76 for 14 yrs.) I can say that anything that helps you accelerate off the line would be welcome.
My '75 has a 38/38 so it's already synchronous, but my wife's has a 32/36. At least, as a '76, it has a 3.91 rear end, which helps acceleration.
Not having used a sync link myself I'd still be inclined to tell you to "Go for it".
If you do, let us know what you thnk after installation.
Bob Napier
I'm w/Bob on the 38/38.
I had a 32/36 and debated for years on getting the sync and decided to bite the bullet and just get the 38/38 and i'm so glad i did.
People talk about them being 'gas hogs' I honestly don't see it. I drive my 02 for pleasure, not as a DD, but even for pleasure I don't drink any more gas than my buddies that have a 32/36 setup...but I don't have the 'bog' that they do. ;)
-Dave
Pittsburgh, PA
67.5 Datsun Roadster
72 2002 Colorado
89 325ix
99 318ti
04 x5 3.0
Don't Do It!
all that power will just blowup your Automatic Transmission
put your time & money into an ATF oil change and
screen cleaning.
before you think something is wrong with your power:
Compression
valve adjustment
throttle linkage adjustment (got Full Opening?)
Auto Trans control cable adjustment
ignition timing
clean new gasoline
clean oil
no tank screen blockage
'64 R27 250cc #383851 18,000m
Brother,
Get the sync-link. The only thing that is gonna blow up from power is your heart from the excitement of the throttle response.
Just from a hands on, practical, I have it experience. I two basic motor O2's with no frills. One has a sync-link and one has a 38/38. Both have been improved by the added carb..sync link and 38/38..
I would say surprisingly that the sync-linked carb gives the 38/38 a run for it's money. I drive both interchangeably. I enjoy both. The sync-linked carb'd car is pretty amazing high end and low end.
I guess the amazing part of the sync-linked carb is the night and day difference between how the carb performs..
I say go for it..
Your automatic tranny is not gonna blow up because you added a sync-link to the carb.
Your automatic tranny. My 4 speed tranny. My 5 speed tranny is gonna fail because trannies fail when they fail.
The added power, lack of oil, cold, heat, gear break, hard starts, high speeds, low speed, wrong oil, right oil,synthetic, dino, my mommas baked bread, etc.....just is
I say do like Columbus, set sail, you will find that the world is indeed round.
There is no downside to the sync-link in my practical experience...
Previously we've had this same thread. This was back when I first had the sync-link installed. In that thread I proposed to the person, if he was not thrilled by the sync-link. I would give him a refund of $50.00........
I give you the same offer.
ira
ssst! i was joking......
"Your automatic tranny is not gonna blow
a sync-link to the carb"
if i still owned a 2002 i'd have a SyncLink
on my carbintrader also!
Brother,
I say go for it..
ira
Did you change CDs Prescription? If so what did you end up with?
1975 2002A
Can the guys that have installed the sync link give any heads up as to what if any adjustments needed to be made to re-adjust the carb? I use CD's set up and it works great for me, but I do want to see if this will make it even better. Thanks in advance.
'76 2002 A "camo blue"
'73 2002 A Chamonix
'71 Airstream Globetrotter
'72 2002 A Verona-crashed then stolen
2007 Toyota FJ
Idle is the only running condition that I recall changing. Check timing while you're at it.
Try installing only the linkage, and test driving. Then go in and add the dual squirter that's under the top cover. Report back with the differences. Also, tell us about the motor. Rebuilt, stock original, cam, etc. Installingand testing in steps like this could help those who have experienced the throttle tip-in hesitation that sync-link sometimes creates.
(O=o00o=O)
