Sign in to follow this
Anschauer
Two and a half questions
2 posts / 433 viewsLast Reply
In the Bilstein pic below you can see a normal rear shock in the center, the two on top and bottom seem to have their ends cut off so the last 8-9 mm is just missing there are no threads.
The upper one also has the piston rod 2-3 degrees bent.
can anything be done to make them useable?
Next, the steering wheel below is shot but I dont know if recovering it is worthwhile - I see no makers name on it but it does say 'Made in Italy".
If it is worth recovering what should it cost and is there a BMW horn button for it?
Thanks in advance
