AmazonGreen
Coil 2002 4-74
2 posts / 364 viewsLast Reply
Hi Folks:
Just finished reading through many posts and threads on correct coil for my car. Been running a blue and learned that's why I have a hot start problem with the Weber.
But it appears a real OEM Black coil is NLA. True or false. If false, anyone have a source? Thanks.
I replaced my coil a few months ago on my '74 2002A. In my quest for the right coil, I measured the value of my ignition resistor wire. I found a resistance of 1.8 ohms. I ended up buying a Red coil which also has a resistance of 1.8 making a total of 3.6 ohms across the coil and resistor wire.
I bought mine from AutohausAZ for about $46. Part number 00013. I think they have the Black coil if that is what you want. NFI by the way.
Peter
'74 2002A
