LeeMW
Electrical problem 2002TII 1972
6 posts / 643 viewsLast Reply
Battery or its connections first. The alternator idiot light is not fused.
Did this just happen all of a sudden or were you working on something when it happened?
I rewrapped the wire harness on my 72 tii last week and had the same symptoms i forgot to reconnect all the wiring to the alternator and that solved the problem,
Make sure that wiring is secure and clean
I just purchased the car and found out about it when I drove it at night.
With the car off and battery disconnected, Remove the plastic cover from the fuse box, remove the fuses, sand the brass contacts, inspect the fuses very closely and re-install if they appear OK.
If the plastic cover for the fuse box is missing, then the contacts and fuses will corrode quicker (than if the cover is installed).
