Sign in to follow this
Mdrei88
FS: S14 Engine/trans w/185k
6 posts / 1198 viewsLast Reply
Selling the S14 engine & gearbox out of my 318is. Planning on going a different route.
The engine has 185k. Compression #'s between 190-205. Lots of parts were replaced by the PO and myself.
Here's a list of all parts replaced within the last 2 yrs.
Water pump and gasket, radiator w/spal fan, VAC silicone coolant hoses, spark plugs, EVO 3 wires w/Gustave's bracket, cap & rotor, E36 timing ensioner, valve cover gasket, rear cover gasket, spark plug hole gasket, distributor housing o-ring and seal, timing cover o-ring, O2 sensor, ITB intake blocks gaskets, rebuilt fuel injectors, fuel pressure regulator, ITB o-rings, intake air boot, alternator bushings, rear main seal.
Transmission - new rear seals, new slave cylinder, M5 guibo
ECU w/Igomotive 2.3 chip
The engine does not come with the AC unit. It's been removed.
Asking $4000 + shipping from 60010
Thanks,
Dan
