Sign in to follow this
Roget77
1975 2002 coughs when turning engine off.
5 posts / 631 viewsLast Reply
Hi,
When I turn the motor off on my 1975 '02 it seems to keep "turning over" and "coughing" for a while before it completely shuts down.
Is this something I should worry about?
Thanks! My first post, probably of many...
Roget.
yes - be very worried
ignition timing
wrong heat range spark plug
over flowing carb float
too much fuel pressure
excessive carbon build up in cylinder head from poor running motor,
excessive oil bypass carbon, sharp points on piston tops
over heating
defective Fuel Shut-Off solenoid at base of carb
so tell us the detailed history about this car / motor
and what's been done ? please
Guest schnelltii
I have the same thing going on with my tii. Should I also be looking at the same things except the carb issues??
it will "diesel[ or "run on"--the proper terms.
If lowering the idle does not help, you need an anti dieseling valve for your idle jet. It´s a solenoid that shuts off flow to the idle jet when you turn off the ignition. Available from weber carb sellers.
cheers
Hi,
Roget.
time it.......... then you will find out its time to rebuild the carb,I guess
