EDIS or 60-2 Trigger Wheel on A/C Pulley?
02Coastie
Has anyone successfully put a EDIS or other type of trigger wheel on a 2/3 belt crank pulley, without impacting their ability to run an A/C compressor? Most builds I've read through indicate milling down the A/C belt slot and putting the trigger wheel in its place. With a likely upcoming move to South Florida, giving up my A/C is just not an option. Are there any other potential triggering methods? What about a flywheel trigger? Any help or thoughts would be appreciated!
"Sabine" 1976 Polaris / Navy - 12+ year Inop Ebay Find. Now with Microsquirt and Cold A/C.
I haven't started on my engine yet so not sure what the 02 flywheel looks like but here's a VW air-cooled link that uses 6 holes in the flywheel as 'teeth' and the distributor for the sync signal which allows for running in sequential.
http://www.shoptalkforums.com/viewtopic.php?f=23&t=138976&view=previous
Solche Fehler sind schon oft von Frisierpraktikern gemacht worden, die keine Ahnung von einer Ventilerhebungskurve hatten. -Ludwig Apfelbeck
I am still working on an AC pulley. Tom at 02again has a pulley and I am thinking of just having a pulley machined to slide over the back and tack welding it in place...
Seems simple enough but I have not see it pulled off yet... I have been jerking around with a Tii pulley but finally figured out that since I am not running a Tii, why not change the front cover.
I am in mid process of doing that between paint and everything else that needs to be done.
I will keep you posted on my progress. Still piecing the megasquirt together.
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
