billjecks
e12 head
5 posts / 611 viewsLast Reply
After much deliberation I removed the head on 73tii , chasing an oil leak, and found the issue of a badly corroded head. Unable to salvage, I am now on the hunt for a good used e12 head. anyone...anyone...
Bill
Vancouver BC
[email protected]
As a preservation tip to others:
ALWAYS ALWAYS ALWAYS use *distilled* water and a 50/50 high quality antifreeze mix.
E12 head should be fairly easy to find. I wish you luck and a speedy recovery!
I had a hard time finding a replacement head for my car a few years back. It seemed like every head I looked at had cracks between the valves. Make sure to check it out carefully. I ended up having one repaired and wished I kept up the hunt to find a good one. It ended up being quite expensive to properly fix it.
Isaac
I'm 99% sure I have a good cylinder head that came off my 2002. I'll double check and get back to you. I'm in the GVRD as well.
-Andrew
