BBL70
what do I need to do about oil consumption?
5 posts / 542 viewsLast Reply
If it is gummed up in the ring area this will do the job at half the cost of the stuff you linked to. It's a diester oil that will dissolve the hard deposit in the ring area and the oil drainback holes behind the oil wiper ring. Pluggage of those holes are the main cause of oil pumping in tired engines. I used it to clean out a 100k mil E30 I bought.
http://www.auto-rx.com/
Agree... good stuff..have also used with sucess. Found out about it reading Bobistheoilguy.com.
Earl
74 02Lux
02 M Roadster
72 Volvo 1800ES
STOP!!!
don't add anything yet!!
how many miles driven since the oil change? ________.
are you checking the oil level AFTER the car is fully
up to operating temp and letting it sit off for 5-minutes
before reading the dip stick? ______.
are you reading the dip stick with a cold motor?____.
have you been topping up the oil with a cold motor
to the top FULL line on the dip stick? _____.
how much oil was refilled at the oil change? _______.
(hint - no more than 4.5 Qts.)
is there white smoke behind you while exiting
the highway from 70 mph and leaving your foot
off the gas pedal?______.
STOP!!!
how many miles driven since the oil change? _800_or 900______.
before reading the dip stick? _sometimes_____.
are you reading the dip stick with a cold motor?_yes___.
to the top FULL line on the dip stick? _yes____.
how much oil was refilled at the oil change? __1 to less 2 qts_____.
off the gas pedal?_no_____.
