trumanwoll
Should I be able to see through the pedals?
7 posts / 688 viewsLast Reply
Pedal box has foam around it which disintigrates. With out the foam the pedal box will have a hole in it that goes all the way through. Use this as an oppertunity to rebuild pedal box box and close hole. Foam is not needed.
"Hey, y'all watch this." I have an old inner tube from a car. I cut a BIG piece and put it between the speedometer cable and pedal box, adjusting to cover the hole. Then a number of tie wraps to various places and in various configurations to secure the inner tube. The idea is to keep road chunks and water from going into the pedal box.
Cheers,
Carl
