Sign in to follow this
scanner
Factory Low Beam Relay
2 posts / 320 viewsLast Reply
The existing BMW low beam relay appears to get its main power (30) via the green wire from the ignition switch through the fusebox, this stops high current going through the light switch but the ignition switch will still have the full current through it? Should i add an additional relay to reduce current to the ignition switch or am i missing something?
There is almost certainly a relay in the ignition circuit somewhere exactly where differs by year..Generally screwed/affixed to the upper firewall either @ lt or rt sd. As seen front driver seat.. I think cylindrical left sd for the later and rectangular relays on the round tail light cars.
