backtrail69
Left Front Control Arm Contacting Steering Box
17 posts / 1401 viewsLast Reply
I am working on reassembling the front suspension on my 2002 after a complete overhaul and installation of a replacement front subframe. I went to put on the left control arm and it seems to be making contact with the nut/shaft on the steering box.
Was there different control arm spacers depending on the year? The right side went together just fine. I am using new OE Control arms and the subframe doesn't seem damaged as the large control arm bolt slid through the holes smoothly.
Thanks
Isaac
I am a little stumped by this, the only thing I could think is that the whole subframe is tweeked on that side causing the control arm to be that close to the steering box. I suppose the only way to fix it would be to un-twist it??
Just looked at mine and it only clears by 1/8th inch or so....Really close!!
I'd say you need to knock that flange down just a smidge....
Dave Ganzer
Thanks for checking on your car, I will "adjust" it this weekend and hopefully it will all clear.
I thinkk you ought to take a look at the tension strut mouning and associate parts to see why the outer end of the wishbone is forward.
Removing metal from a flange on a beam shape is a no-no. It will buckle right there. C'mon structural engineers in the crowd, chime in.
No need to remove metal. Its 2 pressed steel c channels welded back to back. I'd just flatten that flange down a bit to get the clearance. His picture looks like the c shape isn't quite as defined as mine looks. Probably just variation in the aftermarket part....
Dave Ganzer
In that picture the tension rod isn't attached at the other end of the control arm. I was just test fitting the control arm. I think there may just be some variability between my sub frame (Boxed in/Welded), control arm and steering box as they all came from different sources.
You can rest assured I will NOT be cutting anything. I appreciate the concern.
Isaac
Is the steering box also new to the car? I have seen "rebuilt" steering boxes where the pitman shaft sits to low causing this exact situation....
Cheers and HTH,
Yes it is. Rebuilt from 2002AD. Is there anything that I can do to fix this? I am not sure how it could be off THAT much if the box works at all. Crazy.
I'd return/exchange it as defective based on what we're seeing. The bump steer will be wrong for the driver side, the pitman isn't aligned/parallel with the idler arm.
Oh, and keep an eye on your credit card statement if that's what you used to pay with at 2002AD.
I used paypal, but thanks for the heads up. I will look into this this further this weekend.
ditto on tjones, I replaced two boxes this summer for thesame issue, factory rebuilt box had sufficient clearance
What causes it to be so far out of spec?
