Stu
Engine Block Identification
5 posts / 1405 viewsLast Reply
OK, so I knew that the engine in my '76 wasn't numbers matching. But, I didn't realize that the number stamped on the block doesn't coincide with a 2002 block. Here is what is stamped above the flywheel:
21
1484A031
I checked the numbers on Real OEM and came up with two very different results. The site only lets you enter 7 digits (the last 7). An '02 only has 7, mine has 8. Here are the 2 entries and results:
1484A03: A 1985 E30 316 M10
484A031: A 1977 E12 525 M30
Any insight will be much appreciated.
Also, I have an E12 head, stamp below the E12 says "87" so I assume it is an '87 casting.
Those numbers on the block don't coincide with any VIN numbers. It's strictly a parts code signifying that it is a remannufactured engine. Most remannufactured engines in that time were actually new castings. That's a good thing.
of an M10.
It could be a factory remanufactured block. This is the most likely explanation on a US car because an E30 316 engine would be an unlilkely junkyard find in the US--never imported here.
Factory reman engines have all sorts of strange numbers stamped on the serial number pad, so that would be my guess...
(edited)
21
1484A031
Just to close the loop, Stu, the decoding of this information was included in a BMW Technical Reference Information bulletin, originally shared to this forum by JohnH:
http://www.bmw2002faq.com/applications/core/interface/file/attachment.php?id=129207
Thus,
21
1484 A 031
Is:
(1.) a factory-remanufactured exchange engine ("A"),
(2.) for a "1974-75 from 1975" U.S. car ("21", which seems to include California-only 1976 cars, thus the awkward "from 1975" language),
(3.) completed in March ("03") of
(4.) 1991 ("1" AND the 1987-dated head eliminates 1981 if the head has not been replaced since the engine was remanufactured), and
(5.) having serial number 1484 (resets monthly, I believe).
Edited by Conserv
