Passenger side half shaft dropped
warmwaffles
Well this was. I come to a stop sign at the top of a hill and turn right and accelerate, when I lost all power. Motor was running and responding to the throttle, but no movement.
At first I feared it was the drive shaft, because it happened to me once. Got out of the car and took a look around.
Looks like the bolts on the half shaft backed themselves out and sheared right off. Crazy.
http://i.imgur.com/ycgA7.jpg
Anyone know the bolt sizes? I want to try to get this fixed soon so I can have my baby back.
Proud owner of a 1972 2002.
--not sure if you can find 'em at your local hardware store but should be available at an industrial supply place or thru Blunt or other BMW suppliers.
This is not an uncommon occurrance with 2002s--it's happened to me several times over the years. A little locktite on the threads when you replace 'em will be helpful.
cheers
I was afraid of this. I was going to go out to our local tractor supply or Ace Hardware and look for some hardened bolts. :(
I once LOST a half shaft at Watkins Glen. 320i diff allowed flange to pull out after wheel-side CV bolts let go. Track workers found it three hours later! That should happen no longer... --Fred '74tii & '69GT3
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
Fred,
Is that safety wire? I had front struts replaced on my '74 Atlantik blue 2002 back in 1985, garage that did the work did not use safety wire upon reinstalling at a certain point; shortly after picking the car up, was within a few days, I was driving with a friend and taking a turn on to a side street, the front end collapsed; car was towed to a collision shop and folks there said garage that did recent front strut work didn't use safety wire; some body work damage that the garage had to cover as well.
Tim
cheers
Aardvark has the correct ones.
REMEMBER: Loctite doesn't stick to GREASE! Clean those bolt holes THOROUGHLY before installing new, correct hardened BMW bolts. Q-Tips and brakleen if required! Same with clutch bolts and flywheel bolts!
55mm for cars with threaded hub/flanges, 60mm for cars that use locknuts on the hub flanges! Always replace locknuts if you have that type!
I paint mark every bolt I install after I've torqued it with blue loctite. That safety wire is a GREAT idea, though I've never personally had them break or loosen on my own cars.
Paul Wegweiser
I can only imagine the poor soul who found this out the hard way
Yes indeed. Made a jig to cross drill the 12.9 bolts. Bummer about your car, strange the three bolts backed out the bottom of your strut, it's like they weren't even tightened. Like any tool, now that I have the safety wire pliers I am finding all kinds of uses for them. --Fred
--Fred
Happened to me as well in my 1974 2002, one of the allen bolts backed out, did not shear off; happened about a week after replacing the driver side half shaft; there are 6 in total, 8x60mm, part # should be 07119919989
Tim
Any place I can buy these at?
A while ago some lengths of the 8mm allen head bolts were not available through BMW. That may have changed. I got mine (along with a bunch of other nuts, bolts and washers) at Universal Metrics. They source globally, so some are made in China. others are not. Here a link to the bolt you are asking about:
http://www.umimetric.com/catalog/00912020-08060
--Fred
