Sign in to follow this
7002chris
cleanin out garage
13 posts / 1558 viewsLast Reply
all items make offer including shipping from oregon pickup is also ok and required on the big stuff. my email is [email protected]
weber 32/36 air cleaner has a little surface rust the carb is kinda a parts carb but all it needs is the brackets for the barrel shafts where the throttle hooks to could probably order them online
wiper motor SOLD
heater box someone cut the cables and i dont think the fan works good for a rebuilder case in good shape
alternator
black arm rests with the chrome trim pieces SOLD
pass control arm SOLD and a pass tie rod
set of trunk to cabin tubes SOLD
stock springs not sure if front or back they have a blue stripe runnin down one side
2 barrel intake
single barrel intake
single barrel air cleaner assembly could use sand blast and paint or just paint
sun visors really could use a good cleanin but in good shape
clutch pressure plate and flywheel not sure how good clutch is never had it in a car
throw out bearing
clutch fork
black roof handles SOLD
rear pair red marker lights the kind with the bulb not just reflector
passenger door stuff window wing window outer door handle
master cylinder works just needs cleaned up
also have a motor has an alt and single barrel on it pickup only on that
have a driveline needs new carrier bearing pickup only
stock diff from a 75
two axle shafts
I am interested in the 1 barrel air cleaner assembly. How much with shipping to 80420? My e-mail [email protected]
