austinmf
If I have this rust in the rear window should it be down low
3 posts / 425 viewsLast Reply
If I have this rust in the rear window should it be down low in the trunk sides and shock towers?
Makes no sense that I have that kind of rust in the rear windows and none down low... of course I have not stripped the body down low... might be far worse than I am imagining...
if you are lucky, that rust patch could be a result of a hardened and cracked old window gasket allowing water to collect and drip. pull your rear seat up and look around the rear suspension attachment bolts for condition. if it's clean there then you may have isolated rust as shown.
rust will also hide under the rubber seam sealer in the rear corner of the wheel well. you'll need a stiff spatula and hammer and some judicious hits to carefully clear a small section for a look-see.
Thanks Jerry! Looks like it checks out OK thankfully! THanks for the tip and response! I appreciate it!
