Guest Anonymous Posted July 10, 2003 Share Posted July 10, 2003 The speedometer needle seems to be jumping all over the place. It starts out at 80 when you start moving and goes backwards down towards Zero. Any thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 10, 2003 Share Posted July 10, 2003 1. remove instrument cluster and unscrew cable from speedo 2. unscrew cable from tranny under the car 3. Squirt speedometer cable lube (get from auto parts store, or use Lockeze or similar product with suspended graphite) in the top 'till it runs out the bottom. 4. Reinstall cable at both ends, replace instrument cluster. 5. If this doesn't work, it's the speedo itself. They've been known to go a little wonky with age. Take to speedo shop. Cheers Mike Quote Link to comment Share on other sites More sharing options...
