douce02
Roof Skin Swap - Weatherstripping
7 posts / 1405 viewsLast Reply
Hi,
I am about to put the new skin on using the SCR/McGinn method. I know that Bill Williams did this as well.
What weatherstipping / adhesive should be used to go along the top part of the roof structure. The old material didn't seem that healthy when I took the old roof skin off.
See the picture below.
Mike Pugh uses a two part epoxy, Lord Fusor, to put it back together. So strong that the spot welds become a "maybe or maybe not".
Thanks Bill.. So he puts Lord Fusor where the driprail meets the roof frame and then tries to spotweld after using that? I was going to put some adhesive on top of the roof frame where the old foam weatherstripping was and then use spot welds along the bottom.
-Brendan
I do not want to speak for Mike, but I am not for sure that he spots welds at all. The epoxy may be that good.
I remember when Greg put my touring back together, he said the new epoxies make body welding almost obsolete.
hmmm... makes me want to do a carbon fiber roof. should be easy enough if the skin comes off that easily.
easily.
probably 200+ spot welds to drill out then you are home free.
not as bad as the 130 holes I had to drill into hard steel when I drilled my brake rotor on my 72 cb350.
