Sign in to follow this
ziff73
Clock to Tach question
3 posts / 345 viewsLast Reply
Hi all! I'm closing in on the finish line and I just put a tach into my cluster in place of the clock (69' 1600) and realized the three prong clock connector is different than the three prong tach connector...
For those of you that have done this, what's the best way to hook up the tach? Just clip the connector and run separate wires to coil, etc? Or are there already wires in place that either aren't used or can be used? Thanks everybody!
Stephen
I'm far from an expert on the pre-'70 '02s, but all the later cars already have the wire for the tach in place behind the instrument cluster. Look for a black wire, with a right-angle black rubber coated connector, right where you'd expect it to be if you want to connect a tach.
Bob Napier
Wow...I'm not usually that stupid....yep, it was right there under the rubber plug...duh.. I'm going to blame it on a wedding weekend in Santa Ynez/Solvang....;-) thanks!
