Guest Anonymous Posted July 9, 2003 Share Posted July 9, 2003 Hello. I'm new to 2002's & just installed a battery relocation kit. Now the car wont start. It'll crank but not turn over. The battery has full charge. I'm also able to jump it pretty easily. Could it be the statrter? Ground? What? Thanks Rob Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 9, 2003 Share Posted July 9, 2003 make sure there is a good ground wire that goes fromthe engine to the body. and one fron the battery to the body. Also check the voltage at the battery and at the positive on the starter. It should be ove 13v. if there is a big difference between two then the wiring is insufficieant. to thin positive, or weak ground. good luck! steve Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 10, 2003 Share Posted July 10, 2003 wire as the positive. The current needs the same size to flow well. I bet on the previous post, one of the grounds in the engine bay is suspect, retrace your steps in the bay to ensure everything that was grounded got "re-grounded". Quote Link to comment Share on other sites More sharing options...
