Poon
M20 swap : Clutch Hydraulic Question
3 posts / 418 viewsLast Reply
For those of you currently running M20's, what did you do for the clutch hydraulics?
Specifically I'm curious to know which hose/line you used to connect your 2002 Clutch Master to the newer style Slave Cylinder.
The 6 into 2 does go article says to use a VW rear brake hose. Which hose is he referring to, and wouldn't it need to be a double male hose? Since the model and year isn't specifically referred to I have looked at several parts parts lists and have not found one that appears to be double male?
Any thoughts?
Like the E30 hose (#21-52-1-156-673) in conjunction
with a steel line with bracket and standoff.
