Sign in to follow this
V00V
Coil only sparks once
2 posts / 349 viewsLast Reply
Alright... lets take this one on.
75 2002 M10 Vacuum Adv. Distributor
New Cap, Rotor, Plugs, Wires, Coil.
Here is the problem. I turn the key and only get one spark from the coil, then the motor just cranks.
The car was running, (not perfectly, but definitely running before this) I sprayed Rost Off on the linkage inside the distributor to lubricate the vacuum advance mechanics, then this issue appears. I have double checked the internal connections of the distributor and all looks to be in order.
I was fed up with it last night, so I let it be. This morning, still crank no start.
I have swapped the coil with a known good coil, and no change. I have jumped the coil from the battery and still no change. Plug wires are all in the correct locations,
Ideas?
...and SOLVED
Points gap was not adjusted properly. I must have bent the bracket when moving the linkage. Bent it back, and we are in business!
